Does anyone know what points inside the cabin can be used to make sure the boat is level when in drydock?
I am building some stuff where level makes a difference but am unsure where to reference level from when adjusting the trailer.
Another semi-lucid thought. If the mast is plumb on the boat (and the manual says it is until you introduce bend), then wouldn't the top of the mast step be a good spot to reference level on the trailer ?
Ya, I went ahead and used the mast compression post as a reference...then I double checked that against the quarter berth leading edge. They both are level at the same time so I am then assuming the boat is level.
ok, what are you building? holding tanks? a counter? also the trailer or cradle may not be level, but the way you phrased your question.. you understood that.
