Keel Pocket Damage, is there where water is leaking in from?
N41EF
Post by N41EF »
After the trip to the lake last Sunday, noticed that water was still dripping Monday night, crawled under and found this:
Looks like at one time the keel cable broke, the keel swung forward and smacked the trunk. It doesn't feel "soft" but was dripping and was still wet Thursday morning. Could this be where the water was leaking intot he port keel pin locker and the aft port locker in the C22? Water coming in here would go where?
I don't understand enough about how the upper and lower hull are put together, sure looks like water could leak in here but not sure where it goes.
As soon as it dries out I'll sand it out, then do an epoxy and flox repair, and cover it with two layers of Biaxial glass on a 45 degree bias to protect it. Once it's painted to cover it I may make another lake trip to check for leaks again. Do you guys use peel-ply when you do glass work? Of just sand it out?
I did check the keel plates from what I could see look ok:
I do plan to raise the boat, drop the keel to sand blast it and paint it. Will check the rest of the trunk and plates then.
1979 C22 S/V Client Meeting
Banshi
Post by Banshi »
Mine had some slight damage there, not near as extensive as yours but I reinforced it and added a hard piece of rubber to cushion any blows in this area. I have an access hole in this area through the inner hull. This area appears to be reinforced with plywood laid down flat.If it allows water though it could get between the inner and outer hulls and go just about anywhere including passing through the drain holes that connect each compartment.
This is what mine looked like and yes that is what was left of my port keel bracket after dropping my keel out. :shock:
Bhacurly
Post by Bhacurly »
Found the picts from mine...
Same deal... looked like a cable broke an the keel slammed into the trunk. I dremeled out all the corroded and cracked garbage and filled with thickened epoxy.
IMG_8252 by bhacurly, on Flickr
IMG_8253 by bhacurly, on Flickr
DSC00282 by bhacurly, on Flickr
DSC00283 by bhacurly, on Flickr
DSC00286 by bhacurly, on Flickr
DSC00291 by bhacurly, on Flickr
