Today while we had some sunshine, I removed and re-seated my leaking rear Starboard port/window.
Took all the screws out.
I slipped a small thin screwdriver between the Aluminum window frame and the cabin fiberglass and carefully pried it apart. Yuk, what a mess. The windows frame and Hull needed a lot of cleaning of dirt and old 3M 5200.
I cleaned the Aluminum window frame with a wire brush where the old 3M 5200 was stuck on for dear life in some places. Other places it had failed completely. Then I added a new bead of 3M 5200 after everything was cleaned up and reseated the window, replacing the screws and I cleaned up the 5200 that squeezed out from around the frame inside and out.
I'm going to let it dry for a couple days and then take the garden hose to it and see if it will hold the water out. If it works I'll pull the other 3 windows just because, as they are not leaking... Yet, but they should all be done at the same time if the first windows seals the water out well.
Total time was about 3 hours, for everything. I figure I could do all 3 of the remaining windows in about the same amount of time it took to do this one. I have my technical know how down now so it should go quickly.
I had 1/4" plex to replace the old windows with but the OEM stuff is 1/8" and I don't think the OEM frames would take the 1/4" without damaging them so I left the old windows in, scratches and all, for now.
