Hi there,
I'm trying to figure out how you route the lines for the rudder up and down mechanism. I found a diagram that shows which holes the up line goes in and the down line goes in. I'm just not sure if both lines go over the horizontal bar between the rudder cheeks at the top. Does anyone know how the lines are run? Any suggestions would be greatly appreciated!
Thank you,
John
Rudder Sheet lines?
Re: Rudder Sheet lines?
If you go to the documents page where the manuals are , then go to the c26 - bridal assembly the 8th document should show the rudder line assembly. Both lines go up through the rudder shaft.
johnschenkel
That's great. Thank you for pointing that out.
Take care,
John
Take care,
John
