C22 Keel Restoration - Part 3
Posted: Thu Aug 25, 2016 7:55 am
by C22Bob
Finally got the keel installed. Been about a year since I posted Parts 1 and 2. As those of you know that have done it, it's not something you want to do that often, if ever again :)
In Parts 1 and 2 I showed a design for what I'll call 'Keel Stabilizers'. Basically made a skid plate on both sides of keel and used some plumbing parts to form the stabilizers.
The later model C22s had such a stabilizer, but only on the port side. It was made from a galvanized plumbing flange with a pipe nipple and end cap. The nipple had a nylon rod inserted which pressed against the keel.
Here's the one I pulled from my 1980
http://www.chryslersailors.com/discussi ... =12&t=4852
I wanted to build something along the same design, but more robust. The parts are stainless steel and I installed with some tension on both sides. Honestly, I don't know how much it will really help. I suppose with an extremely worn keel pin it might help to stabilize the keel some. Would be interested in hearing comments.
//Bob
Posted: Thu Aug 25, 2016 5:48 pm
by astrorad
Nice work Bob...let us know how it works out under sail.
