Hi All, i hope you are njoying the summer. i would like to replace the factory mast bracket with the hinged type. has anybody done this ? if so what part would work for the c26. would a Dwyer hinge work ?
hi dallasbob, is the stock chrysler hinge easy to use or does the mast tend to slip off the hook ? i havent raised a mast on this hook before, im just wondering if it would be difficult to keep the mast on that hook while raising it. Or is it easier to install one of those hinged mast brackets so the mast doesnt fall off.
