Posting for someone unable to do so -
Has anyone ever found an aftermarket replacement set for these that fits in the same holes ? Or has anyone done a mod to their's to move to a similar set ?
Thanks !
Beau
C22 Portlight/Frame Questions
Odd sizes
Don't know about the C-22, but the C-26 has really odd sized portlights that are hard to replace. The options I came up with were the obvious ones:
J
- => replace the lexan in the current frames
=> cut oversized lexan to cover the old hole plus a border, optionally installing small opening ports through the larger Lexan
=> find an almost reasonably priced oversized port (maybe Beckson, who has some closeouts on sale for about $40 each) and cut a larger hole to fit
=> find a size you like, combo of recutting and glassoing in the old hole to fit as needed, then painting or gel coating exterior to more or less match
J
