My boat came with a set of standing rigging all coiled up and zip tied. A couple airfoil spreaders were included, but no bounting brackets. I canabalized some Dwyer brackets but am not thrilled with the result.
It looks like what I want are the medium size Dwyer spreaders due to the lenngth I need, but the mounts come in 0, 5, and 10 degree rakes. I'm guessing zero is the correct answer because the stock spreaders are round tubes with a base mounted flat onto the mast. I'd be interested to see what you guys have since I want to order right away!
C-22 Spreaders
C-22 Spreaders
Paul...OEM spreaders are round aluminum tubing...7/8 inch diameter...1/16 inch wall thickness...28 inches long...upward rake approximately 4 or 5 degrees by eyeball and protractor...hope this helps.
The spreader bases are solid aluminum castings and the spreader arms slide over the rod that protrudes from the base.
