3D printer
thepartydog
3D printer
Post by thepartydog »
Big brother just purchased a 3D printer for making plastic parts for his boat. It'll be delivered in a few weeks. This will be cool, anyone need any plastic parts?
Darin
"Ya Never Know"
1980 C26
Yep. Nearly all the C26 guys, me, and probably you too....mushroom bearing for the rudder tube !
thepartydog
Oops, me too.
Darin
"Ya Never Know"
1980 C26
Capt. Bondo
Post by Capt. Bondo »
On Jay Leno's garage, they use the 3D printer to create masters that they take to a foundry to get medal parts cast.
http://www.jaylenosgarage.com/extras/ar ... ts-1/#more
8) 8)
Windwalker
Post by Windwalker »
Ditto the rudder bearring!
Re: 3D printer
thepartydog wrote:Big brother just purchased a 3D printer for making plastic parts for his boat. It'll be delivered in a few weeks. This will be cool, anyone need any plastic parts?
Now THAT sounds cooooool!
Tommy Monaco
Post by Tommy Monaco »
I replaced my rudder bearings last year when I had to straighten the rudder cheek. We machined them out of nylon. It's held up well so far.
What kind of 3D printer is it? A rep-rap machine or something else. The rep-rap are REALLY cool. I have buddy who is doing the research and development of the rep-rap at Penn State and running a few classes where they build and operate. Last time we were up he showed me a bunch of the stuff they were making. Really quite mind-blowing actually seeing the future of micro-factory production. Kind of like, if you were to see the first PC in Steve Job's garage, y'know.
Great stuff though, if you can autocad it, the printer can make it, so long as you have a big (or small) enough machine. And since it is self reproducing, you could even progressively make bigger and bigger machines. (or smaller and smaller)
This is a pretty informational website: http://reprap.org/wiki/Main_Page The video is good to start.
Another good site for what you could begin to make: http://www.thingiverse.com/
Rivercruiser
Post by Rivercruiser »
:D Ditto on the rudder bearings! :D
C-26
Hunter 29.5
cs3079
Post by cs3079 »
Rudder bearings...me too, me too please. The cap on my lower mushroom popped off so I snapped a split piece it 2" PCV pipe onto the stem between the rudder and the well to keep it from falling down. It works, but not real good.
Bruce
Poupon Me!
Ray Twp., MI
- Earnest K. Gann
Tommy Monaco
Correction, the bearings I had done were not of nylon, but fiberglass and epoxy. He layered the fiber and epoxy in a PVC tube which had the correct inside diameter for the bearing. Let it set. Cut the billet out of the PVC and lathed it to the right shape (I had given him on of the old ones to use as a guide). I think he only charged me $50, so if anyone wants to get in contact with him I can send you his info.
thepartydog
Printer arrived, it's the Thing-O-Matic kit version here:
http://store.makerbot.com/thing-o-matic-kit-mk7.html
The build area size is 96 mm x 108 mm x 115 mm high. In English that's 3.78 x 4.25 x 4.52 high. Is that big enough to make a mushroom bearing?
Darin
"Ya Never Know"
1980 C26
thepartydog
If I make the hull and cabin top separate pieces, wonder how big a scale model 26 I could make.
Darin
"Ya Never Know"
1980 C26
Rivercruiser
bushing size
My least worn bushing measures approx. 3" dia. and 1 & 3/4" high. So it looks like the machine makes a large enough part.
C-26
Hunter 29.5
thepartydog
Would ABS plastic be appropriate for the bearings? Other types of plastics seem harder to get in the USA.
Darin
"Ya Never Know"
1980 C26
thepartydog
The printer is assembled. Currently working on adjusting settings to get the optimum prints. The settings are printer/plastic specific, so it's taking testing/adjustment cycles. Soon as I get it fine tuned, I'll be glad to make some bearings. PLA would probably suffice for bearings, it is bio degradable, but that's in a commercial composter (high temp)
Anyone have the original size?
Darin
"Ya Never Know"
1980 C26
Rivercruiser
I will send you my best bearing to use as a pattern for the C 26 bearing if you want. Would this help? I would like to purchase one of the finished product and have my original back to reinstall.
Thanks.
C-26
Hunter 29.5
thepartydog
Can probably do it from pictures from different angles showing the dimensions. Does it fit loosely?
How tightly does the current one fit?
Darin
"Ya Never Know"
1980 C26
thepartydog
And just in case I didn't mention it, this printer is really cool. The kit was a bit of a pain to assemble and getting all of the setting right was more pain, but I'm really close to having really good details in the prints.
Darin
"Ya Never Know"
1980 C26
Darrin, I just put a good one back on the project boat last week, but for the cause I'm willing to remove it.. :wink:
Or maybe I could just drop the post and make you a negative half mold from clay while it is on the post. That would show the bearing and the post diameter both ?
thepartydog
EE,
For you I'll just wing it and make you come and pick them up one at a time, till we find one that fits.
Darin
"Ya Never Know"
1980 C26
thepartydog
Does it look something like this?
Darin
"Ya Never Know"
1980 C26
thepartydog
that's an image from openSCAD, from there I can create a stl file that gets converted into g code (commands for the printer).
Darin
"Ya Never Know"
1980 C26
Couple pics...
hp18carr
Post by hp18carr »
Rudder bearings, I got a pair from Idasailor Marine for my C26, have not installed them yet. They may be out of stock... but I'm sure if enough guys call them they may make another run both for the C26 and C22.
Chrysler 26' 1980
