I need a new keel cable, any sugestions on lenght,size, and a good place to have one made up, Im in North Central Alabama we dont a have a lot of marine supply shops here so I have to buy most everything and have it shiped in.
Thank You
David
keel cable
keel cable
david
new owner 1979 c22
ABIGAIL
new owner 1979 c22
ABIGAIL
Mine is a 3/16 stainless steel rope, about 7-feet long. I buy stainless rope from Tractor Supply. Buy a crimper and make your own!
Mine is also 3/16ths stainless cable. Was installed two or three owners ago. I do not know how long it is but would guess 7 to 8 feet.
If I had to replace it I would go to Lowe's Home Improvement in the hardware isle and have them cut me 8 foot of 3/16ths stainless cable and two cable crimping clamp thingies. Run home string the 8 foot of cable then cut it to final size. put in the crimping clamp thingies and call it good for say 10 years. All for under $30 bucks I'm thinking and a couple hours of shopping and a little metal work.
But hey, I'm cheap like that and I know it's been done right when I do the work. I've not had such good luck paying others to do so called good work and then end up re-doing it myself for a quarter the price they charged me after there work failed.
I had one made at Seco South. They build lots of rigging for the manufacturers. I had it made of 3/16" 7X19 stainless wire. They 7X19 is the correct wire for going around a winch spool. 1X19 is more for standing rigging without a lot of bending required. I had them make it 10' long as I can shorten it when I install it. Paid $10, but they are located in my neighborhood so no shipping for me. I looked at Lowes and Home Depot, but the swage crimper was $40.
http://www.secosouth.com/mm5/merchant.m ... g_hardware
$40 for the swage crimper you'll never use again does put it out of price range - which is why I, ah, 'test drove' the crimper at Lowes right there in the store last time I made a spare cable for EE...turbo1168 wrote:I looked at Lowes and Home Depot, but the swage crimper was $40.
