How to paint a straight line?
Post by Paul »
OK so I see all your fancy boats with the new pretty, shiney paint jobs on them. I thought about attempting this last summer when I had the keel out. At least, I thought, I'll do the bottom since I have bottom paint to put on the keel. I grabbed a piece of masking tape and began to run a line to paint to. after several feet I looked, and man was it crooked! Tell me how you get a straight line on a compoundingly curved surface.
Maybe I should have saved this for my question of the week, but I just gotta know!
sauerleigh
Post by sauerleigh »
I remembered this from the past, when I built model ships. The idea is simple, trying to do it on a life size boat, not so simple. http://www.building-model-boats.com/dra ... model.html
If you can get your boat squarely situated on the trailer, side to side (yaw) and fore and aft (pitch), with some help you should be able to pull the boat past stands set up with marking devices. Once the height of the stand is set you just need to move the marking into the hull.
The other way is the scum method. If you dock the boat for a season, you'll end up with a pretty good idea where to waterline is.
1978 Chrysler 26 "Maudie Kay"
It's better late than never
hp18carr
Post by hp18carr »
Scum method... now that's a good one, let nature work it out. :idea:
chrysler 26' 1980
J. Austin
Post by J. Austin »
Simple answer: if u can get your boat "level"; then, the expensive way would be a laser level. ( they can be rented cheap). The cheaper way is a water level. Feel free to expand on this everyone.
jerecaustin.com
Good old method of snapping a chalk line worked for me..
