Mast Base Fix ?
BC
Mast Base Fix ?
Post by BC »
In stepping the mast for the first time --1981 TMI C22 new to me -- the insert into the bottom of the mast that captures the "hook" was very loose and able to move around quite a bit. Looking at it after getting it positioned, the base had been screwed in 3 places with # 12 screws. It seems thou" the rivets had long since lost their grip.
While it's up and held in place by the shrouds I'm not going to fool with it but when I next step it I'll need a solution. Is their an upgrade anyone could suggest for when that time comes?
Thanks BC
mcrandall
Post by mcrandall »
Look for the thread titled "Mast Step Crack." And especially check out John Stahl's photos of his solution: http://s1082.photobucket.com/albums/j37 ... %20repair/
Lots of really good work done in this area over the winter months!
Welcome, by the way!
John Stahl
Post by John Stahl »
I think he is describing the insert in to the mast not the mast step. my mast plate was screwed on too. one screw was loose so i put a dab lock tight thread restorer on it and held with no problems. It could be a bear to get off the nest time.
"Puffen" 1978 C-26
This photo is how I found her
BC
step
Post by BC »
yes John you'r right it is the mast insert that's mangled.
Thanks mcrandall I may be able to use the hinge as is in your suggested link Thanks to both
If any others have a suggestion I'm all ears / eyes thanks BC
mcrandall
Post by mcrandall »
Ah yes! I stand corrected!
Just pulled the top of my mast off. Every screw came loose, too easy, save one. Yep, you know it, I'm drilling and retapping.
