Catalina 22 trailer for Chrysler 22?
- Lucky Jack
Hi All,
I've recently inherited a neglected Chrysler 22 swing keel (on cinder blocks and wood supports) and also snapped up a Catalina 22 trailer in good condition. Any opinions on how well this trailer will match up with the Chrysler? My idea is to use a floor jack to carefully raise the boat up a bit, remove the blocks supporting the bow, and back the trailer under the Chrysler. Once the boat is mostly on the trailer, attach winch cable and crank away. Doable or harebrained?
- Lucky Jack
If the trailer has just bunks, you will want to get the trailer as far under the boat as possible. Once the boat is in the bunks it will be next to impossible to move with the winch.
I soap and watered my bunks down when I moved my C-22 from the cradle to the trailer. Now would be a good time to tighten the bow eye. I used a come-along a few times to move mine useing the bow eye with no problem.
If the trailer has the stands the get a few floor jacks and a 10 long 4"x4"
I'm sure there is someone here that can give you specs on where and hieght on the stands.
Be very careful... this boat could shift and crush, kill in a millisecond....
you need this...
www.portableboatlift.com
I have nothing to do with the company or even know if the product is safe... it just is sold as a tool to do the exact thing you are trying to do...
might be worth it and could save you...
you need this...
"Once the boat is mostly on the trailer, attach winch cable and crank away. Doable or harebrained?"
Um, I wouldn't do the 'crank away' part. With a couple of floor jacks, and a couple of stands, you should be able to walk the trailer all the way under the boat. When I was painting my bottom, I had two stands under the stern ( chained together ), and a floor jack forward of the keel. This was enough to raise the boat almost a foot off the trailer, and IIRC I could have worked the trailer out from underneath if I had another floor jack.
If I was going to try this, I'd have a couple extra stands also, to make damn sure the boat didn't shift left or right as I was changing the position of the jacks.
- LeatherneckPA
Their literature on the site says it's only rated for 2610 pounds and is only recommended for boats 25 foot or less. Even my C-22 tips the scales at over 3000 pounds.NYCSAILOR wrote:you need this... www.portableboatlift.com ... I have nothing to do with the company or even know if the product is safe... it just is sold as a tool to do the exact thing you are trying to do...
They have nice section about the math and how, supposedly it's only lifting half the weight of the boat.
Nice idea, and I believe the physics works out right. But at $1895 each I'm thinking I can come up with something just as good for a whole lot less, when the time comes.
Iron Mike - Semper Fidelis
1978 C-22: Believer
1978 C-22: Believer
- Lucky Jack
Thanks for all the good advice. I'm a bit torn now as to whether to attempt this. Darn these "free" boats. Since the boat is free I'm also hesitant to spend a lot of money on moving her so I'll probably go for the careful but cheap route. Currently the keel is in the up position (may be stuck) would putting one of those hydraulic car jacks directly under the keel and raising the boat there be a bad idea? It would probably only be for a few minutes while I got the trailer underneath. I would also brace both sides of boat while doing this.
I did email the manuf. a few days ago about the weight ( and the draft of my fixed keel c-26) .. he has yet to get back to me....
but his method and design looked good and safer than car jacks for sure.... I always imagined the boat falling on me ...using this forum's .. car jacks method.. and people reading about my death in the local news paper and on the web and muttering////
" ...car jacks.. and the boat slipped out and killed him.... what a dope..what was he thinking..."
- Lucky Jack
Ok, got my boat on my trailer and plan on ramp launching her to actually get some sailing in this year ( don't ask...)
it is a professionally manufacuteres painted box beam ( this might be trouble) double axle from SailTrailers in GA...
BUT...get this.... I am now learning that you should NEVER dunk a painted trailer in saltwater...one dunk and you can start saying goodbye to your prized and expensive trailer...
Others say.. nonsense.. just hose it off right away and real good...
Others say... you need to modify it with drain holes .. flush ports... replace the hubs every year and get some rust preventative inside the box beams...
I don't want to save a few bucks every year on launching and lose a very expensive trailer to rust ( or worse have it structurally fail and come apart with the weight of the trailer on the road!)
but if I don't use it to launch her.. the trailer is pretty much a waste since the yard includes launch and retreival in winter storage and dosen't like storing boats on trailers anyway...
can I ramp launch a painted box beam trailer and still have it araound in a few years...
- Lucky Jack
This might be a good spot for me to mention that the Catalina 22 trailer I had didn't work at all well for this particular Chrysler 22. I managed to muscle the boat on with help from a friend with truck, crane, and winch, but it's only touching the trailer on the keel and bow. That is, there's about a 3 to 6 inch gap between the hull and bunks all around. The boat is also heeling over about 10 degrees atm. I plan to move it back on to stands this weekend then see about modifying the trailer by raising the bunks, etc. I saw a movie years ago about these guys who were moving some nitro across a rickety bridge without blowing themselves up. I felt a bit like this on the trip home expecting any second to watch the boat fall off the trailer.
Upon more careful exam... my boat is a "C" channel NOT box beam construction... but IS painted steel.
I get both advice... "no problem launch it from the trailer and then just hose it off.".. and ..." no way, it is a great trailer and you will kill it..pay the few hundred ( about 500) each time to lift it off with a travel lift.. or fork lift... it is much cheaper than having to buy another trailer in a few years...:
I am also wondering what is the best paint to use to protect the trailer from salt water and rust?
I plan on using my box frame trailer in salt water. It is an older painted trailer that has been used in the ocean many times in the past. It does have rust spots that I have cleaned up and then I used a rust converting primer on it, that is supposed to protect it for 5 yrs, called Rust Destroyer, which I picked up at Home Dumpo. I then just used some Rustoleum professional grade spray paint to cover that. I also replaced most of the bolts with galvanized ones.
I have not used it yet, but my plan is to hose it down after each launch/retrieval, and then inspect it often - especially where parts meet, as that is where water is usually trapped and rusting will start.
I have seem many trailers that are parked near the water that use the lift for launching and are dangerously rusted. So no matter which launch method you use, inspection is the best way to prevent rust. Plan on repainting, or spot painting, at least once a year.
--Richard
'77 Chrysler C26 "Imori"
- Lucky Jack
Thanks Jeffrey. I just ordered some parts from them which I should be able to bolt on with a few modifications.mga1951 wrote:Lucky Jack,
I fitted a v-hull powerboat trailer w/ parts from Trailer Depot (on line). It works like a champ. Dual axle, hydro brakes, all the goodies. My original c-22 trlr I sold for $800.
Good luck, it will work. I tow this one all over with no problems.
