v berth bedding?
v berth bedding?
What do you all use for bedding your v-births??? I find the standard cushions to be way too firm...looking at eliminating them entirely. I can get a king size 4" memory foam pad from ebay for 130 delivered, cut it to fit and use the left over triangles to double up yielding an 8" cushion. I am a little concerned that this might be a little too soft though???
I was planning the exact same thing.... I love memory foam , it is very comfy and very resiistant to absorbing water and has a "cool" feel.
I wasn't sure however if you can just cut it with a blade or scissors like regular foam or does it have to be sealed somehow at the edge.
Do you know what you will do to cover them, make your own ? do you know how much fabric for the v-berth? Do you plan on changing the shape of the cushions so as to get to the storage easier?
It does take up the entire cabin, makes getting to the por a potty a real experience. Its not something I would want to do on the regualr, but we over nighted only once.tnc110 wrote:I have done the queen air matress aft the v-berth...fits nicely, but takes up too much room...I wish i knew how to make a v shaped air matress cause that would be the ticket for the v-berth. Then it could be deflated during the day and stuffed out of the way...
