Although we had very little wind we were sailing on a beautiful day and really enjoyed it. The boat worked as expected except for some motor overheating which may have been due to weeds clogging the intake. I'll look into that more to make sure we don't have an impellor problem.
I didn't know it yet, but the channel leading to and from the launches shallows fast away from center. On our way back in I moved over to give a boat coming out room. I unlocked the rudder, just in case. The rudder hit bottom and hit the prop. I shifted to neutral immediately but we were in a tough spot, unable to steer properly or use the motor and drifting towards rocks. Luckily the soft bottom stopped our drift and gave us time to ponder our predicament.
We were able to push away from the rocks with a boat hook, and then back up with me holding the motor partially tilted so that the Admiral could steer us into deeper water. End result: No damage to boat or family (I wasn't the first one to hit the rudder with the prop) and we "learned" what we already knew, the motor and retracted rudder interfere making both useless.
1 - I'm considering some sort of block to lock the motor in a partially tilted position for shallow maneuvers. Has anyone done that?
2 - We're working out ways to streamline our setup and takedown procedure. Although we didn't buy the boat for daysailing, I think we can get it under an hour.
3 - The mast carriers I made worked well but I'm already planning some improvements including a bow roller on the stern carrier to make the mast easier to move back and forth.
4 - I'm planning some stops on the tongue extension to make it more user friendly to deploy.
It was a good day, with just a little "adventure" near the end.
