So far I'm impress with the quality of the boat (3000 pounds, WOW).
I was looking at CBC22 pictures, and all of them have the winches, why mine does not? There's no evidence on deck (holes, etc) of the winches in case the DPO decided to remove them.
Does the foam flotation expands inside the lockers? Mine came with the silver caps in the starboard lockers (I guess they poured the foam thru them holes) and I can see a deformation on the top of the locker, is that normal? The boat leaked BAD thru the rub/rail, companionway rails and the hole in wich you run the cable for the anchor light.
Mine came with no electric panel, but all the wiring is there, so the next step will be installing a West Marine panel I got for my old boat and never got around installing it.
Well, thanks in advance for any advice
