The top of my C22's mast does not seem to lend itself to the permanent
mounting of an anchor light. I need some suggestions. Pics would
help. Thanks
Need suggestions on an anchor light...
NoRush
Zilbub
Anchor light
I don't remember where I found this on the Internet but you might type in "anchor light" in google and see what you come up with. There was a diagram and explanation for an anchor light that went something like this: Mount a "truck" clearance light (white) on a board that will run up and down your jib halyard. Wires can go to the mast connection that is supposed to light the mast light. Mine works great. Good luck.
