block for genoa
block for genoa
I'm started sailing now does anyone know at what toe rail hole should I put the genoa block on a C-26 from the last stantion forward I have a 170 genoa and a 130 I was waiting for a no wind day to try differt spots but it has been blowing pretty hard lately Thanks
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
--Mark Twain
If I recall my 165 works best with the block at about the middle of the rear portlight, but it's going to depend a bit on the jib itself.
Here's an article I found helpful
http://www.allatsea.net/article/May_200 ... _Placement
Hope it helps.
Hope it helps.
