does anyone know what is in the main sheet bridle mount on the stock C-26 is inside  that hold the blocks down.I made custom risers for a traveler and two screws on one side and one on the other are stripped. I would like to just retap them to 1/4-20 if its a plate I just painted the inside ceiling would hate to cut it all out
Thanks Gregg
						main sheet bridle
Hey Gregg, I think it is just a piece of wood, like the mast step. Was there any residue on the screw threads that could give you an indication?
Also, I just got a piece of track for my C26, and I was trying to decide on what to use for a riser, what did you use, and do you have any pics?
I am planning on bolting all the way through and using a backing plate on the cabin ceiling, I figure that anything that can be beefed up, should be.
--Richard
--Richard
--Richard
'77 Chrysler C26 "Imori"
any help would be great!
I was thinking to use some long wood screws to help it out also if ist's wood in there
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
						--Mark Twain
