Outboard Motor Bracket
Need certain parts, sails, accessories? Put out a request to the Chrysler Sailing Communty!
Please be sure and include useful information like, location, how much you will pay, etc.
skyking
Post by skyking »
I need to find a outboard bracket for my C 22, is there any certain one that i should look for? Also What is the correct location that it should be mounted on the transom?
I have seen them in various locations?
Andiron120
Post by Andiron120 »
Garelick makes some good ones, just have to pick on that is appropriate to the motor you are going to use. My motor is centered and locked down, all steering is done with the rudder. Electric start and controls run just outside the companionway. You do have to keep in mind that he rudder might get into the prop if it kicks up though. Also have to check and make sure there is enough backing in the transom for the mount. I am sure there are some other good solutions also.
