coring on a 22
I tried to install a fishfinder pucket in my boat, and it worked when I put it in top of a zip log bag full of water, but it could not make it work using the baby oil, or the silicone method. After a while I gave up, I have ran aground hard, and nothing really ever happen, I just raise the keel up and keep on sailing.
Then perhaps, I will try it in the starboard compartment. I believe it's where the sink that I don't have is supposed to drain. I can put a little water and place a sandbag on the transducer to try it out. After that, if I don't hear about an uncored area, the transducer will be on the stern.
Thanks for your help
Steve
Steve
I used a Humminbird in my Ensign. If the 22 is like my Chrysler 26 there is no coring in the hull. Heavy fouling will afect the sonar though. In the Ensign the first thing I did was call Humminbird. They have great customer service, actual peole on the phone and they knew the product. They have a program to trade out transducers if the one you have does not quite fit the hull. I got the puck with a 15 degree angle. This came with the epoxy to install it. Before installing the transducer puck I put it in a gallon ziplock bag full of water. Just move it around until you find a spot that works. It helps to wet the spot under the bag. Humminbird also recommended moving it away fro the keel. Remember the signao spreads out in a cone shape it has to be far enough away from the keel to keep the keel out of the that cone. I believe the slope of the cone on my DX 200 model was 1.58/1.
FYI,
I can not imagine the HULL being cored. ANYWHERE. Now maybe the coach top but not the hull. Especially in the older boats.
Now I could be completely wrong but I would bet there is no core in the hull.
That being said, on my 75 C22, the Sette aft of the table on the port side is a perfect place for 1/2 gallon of water to slosh around. I have the anchor and rode there. Thus I simply took the transducer of my $85 hummingbird from West Marine and stuck it in the water. It works perfectly when motoring in flat water which is when I care anyway!
As long as there is no air between the transducer and the water below the hull it will work. However you may loose resolution at greater depths.
Oh yeah, when I said stuck it there I mean I simple set it on the water. It is completely free and can be removed by lifting it out of the water.
I will eventually perminently mount it. Until then, a little extra water never hurt anyone now did it?
I epoxied mine to the inside of the hull next to port keel bracket. The hull is not cored. But any voids in the fiberglass will prevent it from working correctly. I originally tried just in front of the keel right in the center but there must have been some voids in this area as it is very thick in this section. Works great where it is...............now if I would just pay attention to it I would have avoided grounding three time last week
I hear you on the leaks !
Hull number should start with CBC (the manufacturer code from Chrysler). At the end will be a year number like "77", and a month code like "M" or such.
http://boatsafe.com/nauticalknowhow/hin.htm
That's the way I do it, if I see brown I turn around. I also watch the water for short choppy waves (clear indication of really shallow water) and I like to have a chart with me in the cockpit to, and the hand-held GPSBanshi wrote:.....now if I would just pay attention to it I would have avoided grounding three time last week
Well, when its windy in here, its usually sandy and dust everywhere too. I went to the main camp in Victory, and there are some nice little lakes, and I felt like building me up something to jump in the water, but after taking a good look at the waters in here, glad I didn't. Those are the lakes Sadam used to trow dead people to fed the fishes (I kid you not)
Good Banshi... Verification. I based my beliefs on the different sounds between my single hull car topper fishing skiff and the 22. Definitely different sounds. Probably 'as you stated' it's thicker glass.
Thanks all... All I need now, is for this damned -32 with wind chill weather to leave, and perhaps I'll get something done.
Steve
Steve
as mentioned above, anti fouling paint will defeat a in-hull transducer. I have th eoriginal thr-hull transducer and plan on removign it , sealing the hull and going witht ha in-hull' I bought the same transom mount trnasducer you guys have but I also bought a dedicated special in-hull transducer.. now the question is how to test it w/o being in the water... so I guess i need to pick a few test spots now, remove teh antifouling there and then wait for launch to play around with it and hope it works. if not then I guess I revert to screwign it to the transom and then back to a thru hull next year.. not sure how I would run the wires tot he transom mount w/out it looking real ugly
