Each photo will be followed by a question.
Is this the normal way to connect the stanchion to the spreader? The other side is like this too.
[/img]
I am missing the plat that should go above the compression post. does anyone have a clear photo that shows how this should be made or original configuration. Does the wiring run through the post from the factory?
Does the keel pin look normal ? The slathered on sealer has me wondering if there is a leak.
[/img]
I am going to try using a small trolling motor for now but wondered if I could lower the mount (there are bolts 5" lower now) and be able to use a shorter shaft motor (easier to find used)?
Bobby
