After reading the original manual and looking at other mast-stepping photos, I'm curious if our base is put on backwards? From the looks of how ours is set up, it appears that you would roll the mast forward along the bow roller, place the mast into the base, and tilt it up from the bow to vertical. There's a winch that's been installed to aid in stepping it, which is mounted at the back of the boat. Am I crazy, or is this opposite of how other boats are set up to step the mast?
We tinkered around with the mast base and after looking at other photos on this forum, and the looking at the suspect weld on the neck (? Still learning the new language of sailing) of the metal part of the mast step, we concluded that some aftermarket work was done. An attempt to step the mast was unsuccessful in many ways, one of them being that we snapped that base piece off at the weld. Better now than out On the water, I suppose. My question for the forum is about the base of the actual mast. Do I now have a (albeit needed to be cleaned up) normal mast step, if we flip it around to face the stern? What was the previous owner thinking by flipping it to face the bow and welding on an extended "hook"? Part of me is thinking of just switching to a hinged base and scrapping the original mess.
Photos are in the link below:
http://s538.photobucket.com/user/mjappl ... t=3&page=1
Thanks in advance for the advice. We're learning a lot!
