Hi briceburg,
If I may, intervene here:
PLEASE measure your own mast and over all height. It is not a good idea to trust others in such an issue. I am in no way indicating you would get incorrect information from others, I am implying there could be changes to your boat you and others may not be aware of. Especially in a boat the vintage of our Chryslers. Whatever number you get here will likely be right on the money. However, you really do not know for sure, it is simply a very good estimate.
Next time you are at your boat you can do a few things. Use the main or jib halyard and run one of those 100' tape measures up the mast wire tied to the halyard. Measure to the base of the mast. Your halyard will not likely reach the exact top of the mast so add a foot to cover the extra few inches. Now what is on top of the mast? VHF antenna? Anchor light? wind vane? I'd and another foot for all the goodies other than the antenna. Maybe add 2 feet if you have an antenna.
Now measure from the water line straight up and rough guess the top of the coach top. You should easily get within a foot. Always estimate a little high. You can use the bottom paint as the water line if you are on a trailer and can directly measure the mast if it is on a trailer.
With some conservative measuring you can have a good idea of your height.
If the bridge you are going under is even close to your height just avoid it! LOL!
I am of course speaking from Puget Sound where I can simply avoid any bridge that measures within 5 feet of my boats height!
. . . . .and yes . . . . . . I have very personal experience with this issue. I owned a 1978 32' Endeavour. My wife and I shaved every item off the top of the mast. Wind vain, antennas, anchor light, EVERYTHING. Why? because I trusted a good source instead of measuring what I had every chance to measure on my own.
Just sayin' . . . . you have vested interest in having accurate data. Why not collect it yourself. I wish I would have and always do now!
