removing fur from aft birth
aerojet777
Post by aerojet777 »
hi all,
i spend 2 days removing the fur from the aft birth of my c26 then sanding using the random orbital sander. this was alot harder than i thought. i will post pics soon. i decided to remove the fur when i got a spider bite when climbing back there. i think bugs like the fur. the question i have is why would fur be installed in a boat in the first place ?
Fur ? Was it the remains of old foam backing from the vinyl liner ?
aerojet777
fur
Hi EE,, it was actually like fake fur but they glued it to the inside walls of the aft birth. it was a breeding ground for mold and other nasty things so i had to remove it now im painting it so it stays more dry in there.
:D
Ewwww...somehow that makes me think of an old Chevy Van from the 70's or something...bet it was a lot of work...
Windwalker
Post by Windwalker »
My 78 also has "fur" in the aft berth. White or off-white that holds stains, especially rust, very well. I think it was standard in some years. From the aft berth forward its the standard "tuck & roll" white vinyl.
Good luck painting, the fiberglass there is very rough, unfinished. I have been toying with the idea of very thin, 1/8", plywood. I found some at the local plywood shop that is "mahogany", probably Okoume.
Baring that, recover it with vinyl using spray adhesive.
Dave
1976 Mutineer
bearley
Post by bearley »
I removed all the fur in the rear berth area, and removed the tuck-n-roll vinyl everywhere. Is there any reason not to install commercial carpeting on the side walls of the forward berth where the vinyl used to be?
