C22 - Rudder lock out
timlabute
Post by timlabute »
Hey all. Tim here. Wanted to share something.
My rudder has a bite mark out of it from my prop, as seen here:
Image[/URL]
I fixed my motor to the mount on the hard to get an idea of just how bad the rudder interfered with the motor if in it's fully upright position. It was only by a few inches. So...
I noticed an easy fix, and it worked quite well! Let me show you this awful pic and then explain it the best I can :)
Image[/URL]
So, imagine if you will, the red thing in the drawing is the rudder blade, the black lines are the aluminium rudder cheeks. The big green thing is the pivot bolt that hols it all together.
I noticed the pivot point is actually of center, so in effect, when you raise the rudder it does not spin true with the round shape of the cheeks. It actually goes up ever so slightly.
I measured twice, and then drilled a hole through both cheeks, inserted a small stainless bolt, with a lock nut.
Now, thanks to careful measuring, the rudder raises to a point allowing more clearance than the upright keel, but stops when it hits the new bolt. Again thanks to careful measuring, it sits about three inches clear of the prop when it is upright.
Worked out quite well :)
Neat idea ! I always say you can I.D. a Chrysler 22 or 26 by the graceful lines, the shape of the deadlights, the chunk out of the rudder trailing edge....
brings to mind a scene from Captain Ron.."what happened to your Rudder ? "..."shark attack, swab" 8)
Now there is a wonderful idea! Thanks for sharing!
astrorad
Post by astrorad »
Tim, Thanx for that...I will do the same to mine once I build the new rudder cheeks and post.
Chrysler20%26
Post by Chrysler20%26 »
Thank you Tim, that is a great idea. An a good job posting it, easy to understand an well done.
timlabute
Post by timlabute »
Thanks guys! I hope it helps someone experiencing the same issue I was :)
