Bottom paint
excavman
Bottom paint
Post by excavman »
Being new to sailing and boats in general I need some info on how to clean and prepare the bottom for the upcoming season. Any help will be greatly appreciated.
Larry
mariner
Post by mariner »
1976 - C22
"AnneMarie"
mariner
Post by mariner »
and for the next question in line....
"No single bottom paint is the best choice for everyone. The type of bottom paint you need depends on how fast your boat moves through the water, how smooth you want the bottom, how long the paint needs to last-year round or just through the summer-and perhaps the type of paint already on the bottom. Also, paint formulations that are a good match for the fouling conditions in one body of water sometimes give disappointing results in another. The best way to pick a new bottom paint is to find other boaters in your area who use their boats similar to the way you use yours and ask what paint they like. If it works for them, it will work for you. Buy the paint you hear praised most often." - Don Casey
1976 - C22
"AnneMarie"
I was taught this by Captain Scott (69Shark). When I did it I was absolutely shocked at how good it looked and how easy it was to do.
Note: Like Mariner said, I will not recommended a bottom paint. I've done this job once and I just bought the first bottom paint I found. Rust-Olium Marine Bottom Paint at $32/quart from Lowe's Home Improvement. I worked there at the time and got a 10% discount. 1 Quart did the whole thing in one coat. I bought a second quart for touch-up later in the year after a rough handling by the launch crew at my marina one time.
Steps I used:
1. Pressure wash the whole boat top to bottom. Even the parts your not painting. (Because you don't want some dirt dropping down from the upper part of your boat into you new paint.)
2. Do not paint on a windy day. Stuff once again will get blown into your new paint job.
3. Get an Osculating sander. Again I got a close out one at Lowe's for $8.00. Sand the area below the water line with 100 grit sand paper. It took maybe one 8 1/2" x 11" sheet of sand paper to do the whole bottom.
4. Pressure wash the bottom of the boat again to get off all the little bits left behind by the sanding.
5. Mask off from the water line down with blue 2" wide painters masking tape.
6. Fix any scratches or defects in the fiberglass hull. (I did not have to do this as the hull was not banged up at all. Which is good because I don't know how to do the fiberglass part yet.)
7. Get a Small paint roller like you would use on a bedroom in your house. (The one I used was about 7" across.)
8. Paint the bottom of your boat with the roller.
9. Wait 1 hour and peal off the blue painters tape you masked everything with.
10. Take a photo of your work because it will look fantastic beyond you wildest hope. (Well it looked that good to me anyway.)
Oh yea one side note I did not do but wish I had done on my keel:
1. Wire brush the Keel, then Sand the Keel before painting. (I did this part.)
2. Same as above wash off the dusty bits off and let dry.
3. This I did not do and wish I had. Paint the keel in an latex outdoor type paint for the first coat. Not a bottom paint. (My bottom paint reacted with my steel keel and it rusted and started flaking bottom paint just about 6 months after I painted it.)
4. Paint over the keels first coat of none bottom paint with the same bottom paint you use on the rest of the boat.
This puts a layer of latex paint between your keel and your bottom paint so the bottom paint wont react.
Seriously the paint roller does an amazing job on the hull and its fast.
I did the whole job on my boat in maybe 6 to 8 hours. I only power washed once after sanding the bottom now that I think of it. And yes I washed it from top to bottom.
It was probably just my imagination but my boats sailed smoother and faster after I painted the bottom.
excavman
Post by excavman »
Thanks guys, I forgot to mention that the PO gave me a gallon of bottom paint with the boat so that solves one problem. I like the simple way you did it Alan, simple is good, works for me. I'll let you know how it turns out.
Larry
excavman
Post by excavman »
I finally finished the sanding today, what a job. Dirty, nasty, the sanding dust was terrible even with a face mask on. I have a roller trailer so I did all I could get to then used a come-along to winch her back about a foot so that I could do the rest. I'll paint what I can tomorrow and when the paint dries I'll roll her back forward and do the bare spots.
I motored the land yacht down here to Port O'Connor a week ago Monday and have been polishing, waxing and sanding ever since. The weather has been great for working outside. The ICW is about a half mile from this RV park and I can hear the commercial boats going out early in the morning.
I sure hope I can get her in the water in another week or two. The winds have been good for a short trip down the ditch to the Corpus Christi area. That would be a nice 'maiden voyage'.
Larry
Sounding good excavman,
Yea the sander I got on close out had it's own vacuum filter type thing built right into it so that kept the dust down for me. I'd work for about 30 minutes and dump out the vacuum catch container, and start sanding again. I was still wearing a dust mask and I had somewhat of a blue face and hair when I was done. It did not come out on my first washing as I recall. Well I guess that's why I have not had any barnacles on me personally since. :lol:
Thanks for the update, I was wondering how it was coming along. Don't forget to take photos as you go. I never did take a finished photo when I was done. I expected it to be that pretty for years to come. This finish is still good, the color has faded at slightly different rates so the coloring looks kind of bad but again the finish is still going strong just not so much for the pigment. I have to redo the keel due to my not sealing it first. It's all flaky and crusty with rust again with large areas of paint that have come off.
Serves me right, the bottom paint reacted with the keel and rusted toot sweet. It's obvious to me now. Another nube mistake I made and I hope other will profit from it.
mcrandall
Post by mcrandall »
Alan et al-
I was planning on sealing my keel after sandblasting with the same rust killing sealer I used on my trailer (Zero Rust). Then probably overcoating with the two-part I'll use to undercoat the hull.
Any suggestions?
Larry that sounds good to me. I may have to try that myself. I'll be sanding though, no access to a sand blaster. And I'm too chicken to sandblast with the keel still in the hull. What I did to a car body with a sand blaster when I was 17 years old was not pretty. I put a hole right through the body. :shock:
Imagine what damage I could do with a sandblaster on a fiberglass hull with just a little over spray. I would go from a 22 foot sailboat to a 22 foot colander real fast. :lol:
mcrandall
Post by mcrandall »
Thanks Fred! :wink:
My keel will be a long ways away from the hull when this all happens!
Cheers!
Capt. Bondo
Post by Capt. Bondo »
Since Happy Place has never had her bottom painted, and that's OK by me.
She spends 4-5 months in a snow bank. :cry:
A good wax job at the beginning if the season, has worked out OK. Another wax job mid season would be good, but by mid summer I rather be sailing :D
Her bottom does not get much abuse being a dry docked boat used in fresh water...that's OK by me!
excavman
Post by excavman »
Alan,
Almost done, all I have to do is roll her forward and paint 16 little bare spots and touch up around the keel.
I had to do a patch job on the rudder, the PO said he motored into a shallow spot and the rudder kicked up into the prop and the prop was hungry. I mixed up some fiberglass jellied resin stuff from Wal-Mart and layed it out on wax paper, added some fiberglass cloth for strength and slapped it in place using the wax paper to shape it the way I wanted it. When it is almost set take the paper off.
I sanded all the old hull patches, thought about redoing them and decided not to, they held up this long, don't fix it if it ain't broke. Whoever did the old patches didn't sand them very good and didn't prime them either. I am firm believer in using primer. I did have reservations about using primer under the bottom paint so I did the rudder first and painted it. After drying overnight the paint was still looking good so I primed the rest of the patches. When in doubt do a small spot first so you don't have to redo the whole thing if it doesn't work.
I think it came out really nice, Sally Ann will be the prettiest girl at the ball --- or the ICW.
Larry
PS --- Here's the link to the pictures, Thanks for your help. lps
http://s1121.photobucket.com/albums/l50 ... m%20Paint/
mcrandall
Post by mcrandall »
Nice job, Larry! Looking real good! Like how the rudder repair turned out.
Good Lord, I can't wait to get started on mine! Only a couple days til spring folks!
Looking nice Larry!
Congrats getting her done!
Bravo, and a hip-hip hooray times 3 Larry!
Well I will call that bottom painting and rudder restore an unqualified success. Thank you for the pictures and the step by step on the rudder glassing. I have seen glassing done but never attempted it myself. I will do my first glassing this Spring, and I will employee your methods with the wax paper. The fiberglass around my stern light is in need of some very minor repair do to the stern light screws stripping out and taking a little of the glass with them. I lily could fix it with epoxy but I was told long ago by a old salt at fiber glassing not to do that, always use fiber glass.
Jmckamey
Post by Jmckamey »
Great job. Nice looking boat. Do I see some type of mast stepping crutch straped to your trailer?
1977 Chrysler 22
Post by Paul »
Nice job! What year is your boat. I see that we not only have the same paint scheme but also have the same EZ loader trailer. I recognize the wheel fenders which are not capable of standing on (picked my boat up when it was dark and found out the hard way).
Tranquil Chaos
excavman
Post by excavman »
Maiden voyage today. We put in the ICW at Port O'Connor and motored into Matagordo Bay a little ways, straight into the wind. We turned around and put the jib up just so we could say we 'sailed some'.
Larry
Windward
Post by Windward »
Congrats on getting her in and using her!
Good ! You did more than I did on EE's maiden trip out - we motored down Bayou Bonfouca and Bayou Liberty into Lake Pontchartrain, went 50 yards down the channel markers, turned around and motored back - no sails raised that day..
lecker68
Post by lecker68 »
Glad to hear you got her in and got some dacron in the air the first time I had My Getaway out the replica of Henry Hudson's Half Moon was leaving Catskill and sailing south so I went the first 10 miles with them and I was going much faster than the square rigged boat that I had to come about and a starboard tack a short time then a port tack. needless to say I was sailing around them then when I got to where shallow water would affect safety for me or them I turned back and tacked home.
excavman
Post by excavman »
Here are some pictures from yesterday.
Larry
http://s1121.photobucket.com/albums/l50 ... %20Voyage/
Sweet, thanks for the photo's.
clair hofmann
Post by clair hofmann »
Looks nice! Love the pull start extention. That looks like it will save your knuckles.
Cliar
cdmcdan
Post by cdmcdan »
Dumb question here. Is there a way to do the bottom painting without lifting the boat off the trailer? I would like to spruce up my boat below the water line but do not have access to a lift.
David McDaniel
lecker68
Post by lecker68 »
Cdmcdan what I do is paint what is not covered by bunks and I used a floor jack with wood to protect boat keel and raised in stern enough to get there and then to bow for the rest.
excavman
Post by excavman »
I guess you could call my "E Z Roller" trailer an easy painter trailer, also. When I did the bottom last spring I just used a come-a-long and rolled the boat back a foot or so, painted everything I could reach then rolled her back forward to finish up. Simple.
