Information on 1977 Chrysler 280 outboard?
Post All Outboard Topics Here
ststphen
Post by ststphen »
Just got my first boat, a c-22, and it has a Chrysler 280 outboard that comes with it. The little bit of research I've done says it is a 12 hp. Does anyone know if this is correct and/or any other information on this motor? Thanks!
Hi ststphen,
I believe that is a 12.8 HP motor but I'm no expert.
If you go to our main page http://www.chryslersailors.com
follow the documentation link to Chryslers and outboards and you find a little info!
Again, Welcome aboard!
And when it comes to Chrysler outboards you will find no better source for parts or knowledge than Franz Buddenburg at Franz Marine.
http://www.franzmarine.com/
Think "guru". You can tell him I said that too. :wink:
Beau
Chrysler20%26
Post by Chrysler20%26 »
I have one on my C-26, runs like new. 12.9 Hp
Capt. Bondo
Post by Capt. Bondo »
I have a 280 on my C22 also.
More power than you will ever need (but thats OK).
Make sure you keep the lower unit oil filled, there is a needle bearing up high just under the water pump that does not like to go dry :cry:
Parts can also be found at Mercury dealers, since they took over the motor line.
I have done a carp/fuel pump rebuild along with a lower unit, and she's been a real reliable motor ever since.
ststphen
Post by ststphen »
Thanks for the input and warm welcome guys! Can't wait to put her in the water!
