OK! I'm a rookie, and am not sure about how to describe the help I need. I just removed the rudder and noticed some definite problems. Mainly, the hole in the center, on which the kick up rudder rotates, is not round anymore. It's sort of oval shaped, which causes it to... not pivot, but shift, but not smoothly. Doesn't seem secure. So... can I repair the rudder itself, maybe with a metal bushing? Or do I need to look further?
Any suggestions are greatly appreciated!
Chrysler 22 rudder repair
Robbie: check my website, I did the rudder repair this summer.
http://www.flickr.com/photos/gus_chrysler22
Gus
Gus
If the hole in the rudder itself is out of round, you could drill the hole out to a slightly larger size, epoxy in a proper sized dowel as a plug, then redrill the hole to the original size. Be sure to waterproof and coat the inside of the new hole to keep the new wood from swelling around the pivot bolt.
Leaving enough room in that last step for a bushing between the bolt and the new hole might save you from doing it again one day.
Good Luck, save us some pics of the process !
Beau
Beau
