 .  (Son is at camp for the next two weeks
 .  (Son is at camp for the next two weeks   ).
 ).  The previous owner essentially resurrected the boat after it had been left on a beach in Wisconsin sadly neglected for several years (hence our name for the boat). He found that the foam inside had deterioated (squirrels
 ). After doing some research, he filled the hull with 2 liter pop bottles (lids on) for bouyancy and then proceeded to sail the boat for several years.
 ). After doing some research, he filled the hull with 2 liter pop bottles (lids on) for bouyancy and then proceeded to sail the boat for several years.Question. Should I consider replacing the pop bottles with a spray in foam or other foam system? If so, any recommendations, and has anyone actually done this? I know there are some kits on the market that are recommended for marine use with some purportedly meeting coast guard qualifications.
I also have read some posts on some other forums where folks have used the pop bottle remedy. Water noodles and insulation foam from Lowes or home depot have also been suggested.
I look forward to any or all suggestions. I will be sure to post the results of our maiden voyage.
 So again, I vote to leave the system in place for now with maybe some tidying it up so they don't rattle or whatever, and no I wouldn't worry about sealing them either, to much work for so little result, check the caps so they are snug, maybe...
