Cushion Replacement
bearley
Cushion Replacement
Post by bearley »
Hi All,
Did the original settee cushions in the C26 have a thin plywood base? Mine do but I can't tell if it was original or added when the PO recovered them.
lecker68
Post by lecker68 »
My 26 does not 1980 hatches in setee in salon have plywood cover.
Dallasbob
Post by Dallasbob »
Bob T . . .
1979 Chrysler 26 "Indecision"
Dallas, Texas / I-45 / Galveston Bay
monty
Post by monty »
no plywood on mine, they are original, I believe.
Messing About
No plywood on mine, not 100% sure they are OEM. I'm thinking they are mid 1980 colors instead of 1970's colors so I have my doughts as to there origins.
Dallasbob
Post by Dallasbob »
I don't think a manufacturer would go the plywood route. I think they would want a higher quality look for prospective buyers flipping the cushions. I'm glad mine came from the PO that way because I had never seen it and it showed me a way to escape having new cushions done professionally. Something I can afford and cheaply. Custom stuff is way too expensive for me.
Bob T . . .
mcrandall
Post by mcrandall »
Bob T-
Please post a picture when you get a chance! Cheap and easy, that was my nickname in high school....
hp18carr
Post by hp18carr »
Cheap and easy... no offence, but it may not fit now that you are older. I did a little shopping around to get a ballpark figure on the cost of building a free standing lift system likes yours, again very nice by the way. I don't recall if you did, but I chose to go with treated lumber and S.S. hardware where I could... it maybe my own doing but my ballpark is hovering around $1000. :shock:
Chrysler 26' 1980
mcrandall
Post by mcrandall »
OK, I admit, I'm not so cheap anymore....
Tell you what, I'll re-price mine out next time I go to the lumberyard, but I don't think I have much over $300 into mine. (Come-alongs and straps NOT included.) Granted, mine is smaller by a section than what I would make one for a C-26, but.... Also, I know my lumber was on sale, but that shouldn't make that much difference
I used zinc coated hardware. Let you know what I find.
NYCSAILOR
Post by NYCSAILOR »
Just redid my OEM cushions for the C-26.. had it done professionally with sunbrella and memory foam in the v-berth...2G's.... figure it is was needed, would take me forever to sew ( I don't know how but have a machine) , a once in a lifetime project, would enhance the resale value ( something has got to help!) and I would enjoy each time I am onthe boat....
THe OEM salon settee seat BACKS were backed in plywood that was then screwed to alum angle brackets to the inner hull liner...
BTW: I thought about changing the configuration a bit and making thisngs more comfortable or more flexible seating or more modern... but that became a big project in and of itself and I realizzed I was just delaying getting it done...so now it is done...
I still ahve to paint hte interior white ( is still OEM "almond" ( I know I should have painted FIRST and then put in the cushions...)
C-26, Fixed Keel # 343
blu by you
cshions
Post by blu by you »
i just started recovering mine they have fabric on one side and vynil on the other and they are original, i am using the plywood method it is MUCH easier and a lot cheaper
NYCSAILOR
Post by NYCSAILOR »
The OEM cushions did have durable vynil on the bottom, I did the same with sunbrella on top... if you go the plywood method -- be sure and use stainless steel or alum staples!
Papax3
duh!
Post by Papax3 »
You guys are brilliant!!!
You just minimized the pain of my next big project....!!!!
redoing my cushions as well!!! Now that I'm thinking about it,
the plywood/foam/fabric/staple-gun method seems exceedingly simple.
Why didn't I think of that?? I'll use a bigger foam pad and compress it alot, I think. Gotta make it comfy.
Thanx!
Bill Williams
