weldon wrote:Thanks Woody, What kind of problems did you have with the keel? I know I need to replace the cable before I take it out. I just ordered a new main but thanks for the offer. I also purchased the boat this spring and thought I would have it in the water by now ,but we have had the wettest summer on record this year in south tx and I'm not making good time on the repairs. I will try to post some pics soon.
Weldon
Weldon, my problem was not with the cable but with the pully which directs the cable off the winch. Believe it or not a mouse had built a nest
up against the wood block that holds the pully bracket which caused the wood to rot and kaboom!. So after much fiberglass repair and some inginuity with wood blocking, bigger bolts,etc., Im sailing again!! Its not the best desiign, the original so I improved it. Amazingly the winch seems to work with a little less effort. As far as your cable goes there was some discussion on the board regarding stainless steel vs. line for replacement. I have no clue as th the weight of the keel, best guess 2 -300 lbs? My way of thinking is stick with the stainless steel, wont rot over time.Of I can be of more assitance, give me a whistle. Got to go the wind is blowing!!
