Hi all,
I just pulled my Dia for the season, and she is going to spend another restful winter in my driveway. My C22 does not have the rear railing, and I was thinking about making a support for the mast back there, probably coupled with something at the bow. Does anyone have a picture or drawing of a support like that, before I start to wing it ?
Mast Support Jig
Sorry I can't locate a picture. Hubby put something togtherfor transport and storage using scrap that was around, a peice of plywood about 18 inches wide 3 feet high with a notch cut on top to rest the mast. He screwed it to a 2 x 4, flat edge down, along the bottom edge wide enough to go laterally across the beam of the cockpit.
Drilled two holes on either side up high and fed line through which we secured to the U bolts on the stern, two holes on the bottom which we secured to the stern cleats.
Hope this helps.
Hope this helps.
- clair hofmann
Do you take your motor off to tow? You could make a support out of some 3/4 plywood and a 2x4. Cut the ply to fit the motor mount and extend up past it long enough to bolt the 2x4 to it. Cut a vee in the top of the 2x like Alan did then or clamp the plate to the motor mount.
I use something similar on my Ventures but they have transom hung rudders and I simply use the gudgeons.
