Outboard Advice
- Lucky Jack
Outboard Advice
I am trying to find an outboard that will work on both a Chrysler 22 and a Victoria 18. What I have in mind is a 3.5 hp four stroke Tohatsu:
http://www.onlineoutboards.com/Tohatsu- ... 3-5BL.html
It's more than enough for the Victoria but is it strong enough for the Chrysler? At the moment I sail exclusively in lakes so no currents to deal with. I've been haunting the local Craigslist, but so far the prices I've seen there are no bargain.
For relatively calm flat water that outboard is more than plenty to get to and from the dock or piddle around. However if you are in heavy winds or anytype of seaway you may find it lacking in ability to power home.
As a sailboat that should not be an issue since you could SAIL! but just be aware in 20kt winds you may not have enough.
- Capt. Bondo
Not to be the one to drag this post past it usefulness, but at some point I'll be installing a new motor on my c26. Capt. Bondo's statement of having the power when you need it is valid... but is there a happy medium between power and weight? New motors with a H.P. of 9.9 or higher seem to weigh in around 80 to 90 pounds and we all know the motor mount on a c26 is not the strongest in town. In a nut shell... I'm I destine to reinforce my motor mount to the point where it looks like a mini fork-lift.
Chrysler 26 1980
![Shocked :shock:](./images/smilies/icon_eek.gif)
Chrysler 26 1980
- Lucky Jack
On a side note about horsepower. I have a 9.9 Mariner on mine w/ electric start. I had a new 4 stk, 6 hp Merc. Realized if anything happened to me, my wife would not be able to pull the cord hard enough to start the motor.
I dislocated my shoulder 2 yrs ago and then it hit me. I need an electric start outboard.
just an idea to think about!!
Jeffrey
Fore Sail
1976 C-22
Fore Sail
1976 C-22
