 The rudder has always had a seam where the two halfs joined. The joint was solid, but I beleave a little open that would allow water to drain.
This worked for me since the boat is dry docked.
As I'm making this repair, I wondering of I should seal the rudder up tight, or drill a couple weep holes to drain water.
My consern is that if I by chance water ends up inside, and freezes in the winter I'll be doing more glassing in the spring
What are your thoughts?
