OK so now I have these images loaded into a easier to access database.
http://s954.photobucket.com/albums/ae27 ... /Sailboat/
1) There are several different types of Fiberglass resins/coatings which ones should I use in the 2 different hull pictures?
2)For repairing the crack in the rudder what would you guys/gals recommend?
Thank you for Input!
Rudder/Hull Repair? -- Photobucketed Images
- sauerleigh
- sauerleigh
I did not intend to work on my rudder tonight, but. The pics may give you a better idea of the work I am trying to describe. All the materials you'll need are probably available at your local auto parts store. http://www.flickr.com/photos/93952888@N00/
My boat has not been in the water for two years but it was stored uncovered until I purchased her in early April. The rudder was removed and stored in my garage since then and the foam core was still wet when I removed the SS tubes that house the rope knots.
1978 Chrysler 26 "Maudie Kay"
It's better late than never
