Hello all, I finished up removing the glue from the interior recently - very impressed with the results. Here is a quick before and after photo:
Before:
After:
Ready to rumble:
Basically I followed this method:
1) Bought a 3M respirator, wore goggles and used thick rubber gloves. Also opened every window available and put a fan at the main cabin door blowing air inward. Also, it was a breezy day when I did the work which helped. These fumes are really awful - do what you can to properly ventilate!
2) Used 3M General Purpose Adhesive Remover. Applied it with the following methods: spray it on with a spray bottle, dipping rags in a bucket full of it and continually running the wet rag over the areas, or just laying the saturated rags directly on the surface.
3) Left it on for 15 to 30 minutes until it turns a little yellow in color - then it is really dissolving and ready to scrape off.
4) Used 3 sizes of brass brushes to scrape off the dissolved glue.
5) If the initial application of the remover doesn't completly remove the glue - keep adding more to keep it wet with the stuff and keep scraping with the brush; it will dissolve eventually.
Well that's it - this stuff is gone now and the walls are clear.
Regards, Bryan
