cored hull?
cored hull?
I want to install a depth sounder, the kind that has the transducer inside the hull. The manuel says that this will only work IF the hull is solid fiberglass, not cored. Okay, does anyone know for sure if the 26 has a solid fiberglass hull or is there a core of balsa wood inbetween ?
EE, I know it seems thin, but you can imagine how many layers of glass that is. Back when I was a pup, Catalina had the retarded idea, becaus aluminum was cheap, to thin their cores and ad more ribbing. This was mostly made out of aluminun. Making them topheavy and flexible. I saw one cut-up for scrap, and right by the keel-box area they cut around the ballast, and took a caliper to the thickest part. .375!, yup 3/8'', it was an ey opener. I will say that there are parts of the 22 that I would have "beefed" if I was molding it, but They built em' pretty well in the 70's.
jerecaustin.com
jerecaustin.com
- sauerleigh
Mario G
