How do you install these
snowbordlb
How do you install one of these? Do I have to replace the entire cable?
http://www.westmarine.com/webapp/wcs/st ... /0/0?N=377 710&Ne=0&Ntt=stay&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=stay&isLTokenURL=true&storeNum=130&subdeptNum=10902&classNum=10902
Before running out and buying that, check you boat.
The aft stay on the C22's is split. There should be an aft stay adjuster there already. Maybe it is missing? Maybe it is free floating and not hooked up properly?
Here is a picture of it. Hard to see but it is there top left of the photo!
This photos was shamelessly linked to at chryslersailing .com
snowbordlb
I have one but it is worn out. The adjuster is smoth so it is hard to turn i guess once i get it set i can just leave it but i figured for $39 it might be nice to have a new one. I was looking online and it says something about swage connections. I dont know if you need a special tool for that or not
somers12
Ha funny,
I noticed that too.
In Steve's defence, a press is kind of a really large, slow hammer.
I noticed that too.
jerecaustin.com
jerecaustin.com
snowbordlb
- Capt. Bondo
I don't think C22 came equiped with back stay adjuster standard.
Mine does not have one and does not appear one was ever installed, no holes.
I'm thinking of installing one of these split adjusters
http://www.defender.com/category.jsp?pa ... &id=298804
