Evil Electrolysis - Don't let this happen to you!
Posted: Sat Mar 14, 2009 3:56 pm
Fellow Chrysler Sailors,
I thought I'd post a new topic so that others may learn from our experience (and mistakes!). We bought our 1978 C-26 a few years ago and have systematically gone through and renovated just about everything on the boat. Before the boat went in this season, I wanted to be sure and inspect a critical part of the boat not previously inspected--the rudder post assembly.
It took a lot to get the aluminum rudder post collar that sits below the tiller off. To remove the s.s. allen head bolts used to attach the aluminum collar to the s.s. rudder post required several rounds of heat and solvent to free them. The head of one broke off and the remainder had to be drilled out. This was the first clue to the problem of adjacent dissimilar metals without Tefgel or a similar barrier in place. Removal of the aluminum collar itself also required heat, solvent and impact.
After we dropped the rudder post, we were able to inspect the rudder bearings and other parts of the assembly. The lower bearing was badly cracked and seriously out of round, but the upper was not too bad, except for the accidental scorch from the blow torch when we were heating the aluminum collar. Both bearing seats will need some attention since they are grooved and have delaminating or missing gelcoat.
We noticed some heavy pitting on the head of the rudder pivot bolt when we removed the rudder in order to drop the assembly. This was bad, but just the first sign of corrosion problems we would discover. We noticed some tiny holes in the s.s. collar on the rudder post just above the rudder cheeks. They looked tiny on the surface, but probing with a screwdriver revealed much wider and deeper penetrations into the body of the metal. Upon doing some reading, this appears to be "pitting corrosion" which can cause serious structural problems as it travels well below the surface.
Once we started looking, we found a number of similar areas, but none as bad as that s.s. collar. From my reading on the subject, all this could be caused by one or more problems that we may have innocently/ignorantly contributed to:
1) Used 304 stainless fasteners below waterline. Somehow, when the boat was on the hard I didn't think of using 316? Duh.
2) Before launch 2008, I painted the rudder cheeks with antifouling paint without a metal primer applied first. The copper in the antifouling paint can promote galvanic corrosion between dissimilar metals.
3) We may have a wiring issue which could have resulted in stray current entering the water, though I'm not sure how. On my list before launch this year is to figure out why the bow/stern lights are not working, while the steaming light controlled by the same switch is.
4) No zincs on the rudder cheeks. Strangely, our rudder has a hole toward the aft portion which appears to be intended for a zinc. We attached one, but from what I've read the zinc needs to be in contact with metal (not the fiberglass rudder) to do its intended job.
It's a good thing we inspected all this before going in the water this year. You will see from the pictures I've posted, that the bolts were not far from becoming useless. Leaving all the same as last year could have resulted in loss of the rudder and/or use of the control lines (for what they're worth).
Our plan for repairs/remedy are as follows:
1) Grind out pits and fill all pits with epoxy/silica mixture.
2) Remove antifouling paint and use a metal primer intended for submersion before reapplication of antifouling.
3) Attach zincs at rudder pivot bolt and rudder control line spacer bolts ensuring bare metal contact.
4) Inspect and fix wiring issue with bow/stern lights.
5) Replace all fasteners with 316 stainless steel.
6) Inspect rudder assembly annually.
I know the epoxy is probably a temporary fix, but short of filling the holes with weld, it's probably the best approach. From what I can tell, the s.s. collar above the rudder cheeks acts as a spacer and does not appear integral to the structure of the rudder assembly. If others have other suggestions for repairs I'm all ears!
Please see photos at http://www.flickr.com/photos/36339036@N ... 264580528/
Best wishes for happy and safe sailing!
