Lone Star 13 Refurbishing Project
Posted: Mon Mar 17, 2008 7:17 pm
Fellow sailors please help! I have finally decided to refurbish my LS13.
In preparation for sanding and painting, my first task was the removal of the old dried out rub rail. This revealed a 24-30" section of separation of the Deck & Hull joint on the Port side aft due to the rub rail being damaged or parted from the joint. The fiberglass of both the Deck and the Hull in the separation area looks sound; it appears to just be years of saturated flotation foam under the deck fitting that has caused this condition. The Hull does not want to give at all in rejoining the Deck joint.
What are my options for repairing this situation so that when (and if ) I locate a new rub rail I will be able to install it properly? Should this be filled and then sanded down fair to receive the new rub rail...?????
Also, has anyone ever dealt with locating a modern replacement rub rail for for this charming little classic?
I welcome your suggestions.
