Cradle or stands
Posted: Tue Feb 26, 2008 12:43 pm
by thepartydog
Ok, I got a chance today to make a thorough visual inspection of the bottom of the boat. Many nicks, and what looks like a silver dollar size indention in the side of the keel. It's way down by the opening for the keel pocket. I don't know if the indention will let water in the boat, but the bottom is in rough shape. The bottom paint is worn away in some spots, and there is even a few chips that expose glass fibers. Now, I'm not so sure about putting her right back into the water. So, on to my question. Where do I get stands or cradles in a hurry? Can I build a set of cradles? I need to have the trailer back by Friday.
Darin
Cradle
Posted: Tue Feb 26, 2008 12:59 pm
by Windwalker
Dog,
I have a copy of a "Good Old Boat" article in electronic format on how to build a cradle. I will be happy to send it to you. Contact me via private message or email with an email address if you want a copy.
Good Luck.
Posted: Tue Feb 26, 2008 1:36 pm
Posted: Wed Feb 27, 2008 5:47 am
Took a couple stand pics this morning, if I was doing them again I'd add some ply gussets, but as they were they were steady- most of the load on them isn't bow to stern but from the pad to the ground. By placing the rear of the foot hard against the ground, then pushing/wedging the pads under the hull so there was a bit of push against the hull on each side they stayed rock steady even after the cradle was removed. In these pics the boat is not resting on any trailer bunks, but only the stands and she's sitting steady.
http://my.att.net/p/s/community.dll?ep= ... 313507&ck=
Posted: Wed Mar 05, 2008 12:18 am
by thepartydog
A friend ended up building 4 metal stands. I helped, so they are not perfect. She's also blocked forward of the keel, and is still standing after the big winds over the past two days. I'll post some pictures when I get a chance.
Darin
