Converting onboard to outboard
My C-26 has a gas inboard and I'm not thrilled with the idea. If it was diesel I'd probably leave it alone, but I'm considering converting to an outboard instead. I recognize the there can be issues with transom, weight distribution, etc. Has anyone had luck doing a conversion like this? Any tips?
Re: Converting onboard to outboard
I just finished closing up the huge opening in the transom and adding a heavy duty adjustable motor bracket. I have a slide show of the entire process I can try to email or text to you. My address is gmgarymi@gmail.com, you’re welcome to contact me.
