Repair help - 22'
Posted: Tue Oct 12, 2021 5:51 pm
Hey folks,
Just joined the forum and thought maybe I could get some help or perspective on a few things.
I noticed my boat was sitting a little cockeyed in the water. The starboard side sits a little lower than the port side. I also keep getting water in my starboard storage compartment at the front of the kitchen slide, just above the keel bracket. My thoughts are that maybe that side of the boat is taking on water and it's filling up inside the hull under the tracks. Has anyone cut open the side of this and put in an access to see what's inside? I was thinking I would seal it with a waterproof inspection cover. I also wonder if water is coming in from leaks in the toe rails and running down?
I also need a new upper through hull for the rudder fitting, anyone have any good recommendations for this?
I need to reseal my toe rails and plan on taking them off, any big issues to expect?
Anyone have any experience repairing spider cracking in the gel coat?
Thanks in advance!
Tony
Thanks in advance!
Tony
