shroud tension question
Posted: Mon Sep 03, 2007 7:14 am
by ronc98
I need some help in setting up the tension in my shrouds, back stays and read stays. When I rigged the boat for the first time it was just me and I do not think they are tight enough. The shrouds on the leeward side of the boat always seem to have a play in them. The mast learns a bit from the wind pressure on the sails you can not visually see this however you can tell from the shroud tension. I am sure some of this is normal but I am not sure how much. I wonder if some of the damage on my mast step is from the mast jerking from side to side during tacks.
Any advice on setting the tension?
Posted: Tue Sep 04, 2007 3:27 am
by matt
As far as the side shrouds, my understanding is that with the sails down, they should have equal tension. I give mine a pluck and it should feel like a little less taught than a bass guitar string. When you are under sail, the leeward shroud should infact be less taught. This is normal.
I actually have a friend that uses a fish scale to measure the tension on his shrouds to verify that they are equal. I think for a C22 this may be overkill.
I think some other folks on the board may have better advice regarding the forestay or the backstay.
