How do you remove the table top?
Posted: Tue Sep 01, 2020 7:27 am
by CLS72
Seems simple but have not been able to figure out how the table dismounts....unless the previous owner bolted for ever.......can't see a lock or way to remove the table without taking all screws out......
Re: How do you remove the table top?
Posted: Mon Oct 05, 2020 9:20 am
by CLS72
Had to remove all screws from the base; looking it now, it is hold by pressure only - but it was completely stuck after stepping / seating on top ! so will clean and put some type of stop to avoid the same issue
