Backstay adjuster on C-22
Posted: Thu Jun 02, 2016 6:08 pm
Hello again. I wrote about this backstay issue about a year ago, but never got the boat on the water. This year, though, I've rented a slip and have time to get it on the water, next week, I hope.
Here's my issue. I'm feeling pretty confused right this minute. The split rear stay apparently needs to be adjusted. The previous owners had several turns of rope wrapped around the backstays to provide tension. I've purchased a C.S. Johnson backstay adjuster that will do the trick much more nicely.
Here's the adjuster:
Here's my confusion and problem.
1. Where would I, could I attach the line to tension the adjuster. There is no place, though the pick up eyes on the back of the stern would do, I suppose. Did this originally attach to the aftstay chainplate? The document that refers to this is vague: http://captainscottsailing.com/Chrysler ... tStay2.pdf
2. Looking at photos of C-22s on this site and online, I have not been able to find any with backstay adjusters. So, what gives?
Is the backstay adjuster only optional? Given the way mine was tied up, I'm envisioning that there must be a fair amount of slack when the mast is raised, even though the length of the backstay cables are the regulation 5 feet.
I'd appreciate any input. I want to get the boat in the water within the next 5 days if possible, so I'm looking for a practical solution.
Thanks!!
Thanks!!
