mast cleaning
mast cleaning
I have a Pirateer and am wondering what is the best way to clean the aluminum mast and boom. Is the aluminum anodized?
Re: mast cleaning
I clean my mast with Spray-Nine and rags. For harder spots, a 3M medium sponge. Also baking soda helps cut areas with greasy or gluey smears. Then at the final step I like to run rags through the channel tracks and mist with McLube or silicone spray.
I do this with the parts laid out on my lawn, propped up on firewood logs. Lots of space helps, so you can draw away all the lines.
