New Owner
Posted: Sun Oct 04, 2015 4:06 pm
Yes - it's strange to be new to something that was made in the 70's - Friday I took the plunge and purchased a C22. I now realize the boat needs more work than I initially thought (isn't that always the case?). After I got it home, I pumped out about 15 gallons of water. There's plenty of caulk around the keel pin. The rudder looks to be in rough shape. I've learned from this website - that this is typical (and I'm up for a project).
Here's the part that I haven't read about - the keel winch had been mounted with through bolts to the bridge. It clearly suffered from prolonged water damage, became compromised, and the bridge eventually caved/broke. The winch assembly is now loose in the boat.
My question is, where is the winch supposed to be mounted? Was it through bolted?
In spite of the growing project, I think it's a beautiful boat and I'm thrilled to be on the path to sailing.
