C22 mainsail backhaul
Posted: Thu Sep 03, 2015 11:38 am
Hey!
I've been searching all sort of images on Google, and through the Chrysler Sailboat specs./ rigging data {stumped}, but I'm still trying to figure out what the original running rigging configuration is supposed to be on my C22, where Mainsail backhaul is concerned.
Port side of boom, closest to transom, has a small clam-cleat facing bow to stern, intended to clamp at the bow-end. It also has a riveted pass-through upside down "u" at about the same spot.
At the boom end, there is no block, no turn-around that I can tell, and other than using the clevis pin itself as a turn-around, I'm not sure what was intended.
Starboard side of the boom looks reefy, with a small surface-block towards the boom-end, and a clam cleat all the way at the mast end... sort of a jiffy-reefing type setup.
I'm not real happy with the backhaul setup, given that tensioning the foot of the main is cumbersome, difficult {not smooth}, and that it generally seems to slip, with no way to really keep tension on the foot.
PICS of your setup would be greatly appreciated!
I realize there are a billion ways to do it, but mine is currently a make-do situation. I'd like to be more sure of the correct way, since I want to install a system that allows me to quickly transition into reefing the mainsail.
PICS, PICS, PICS !!!!
Thanx!
Bill Williams
Safety
Thanx!
Bill Williams
Safety
